I didnt realize when i got this, this needs to be on a breadboard of some kind. I thought it was going to be solder. what board would you recommend?https://www.semiconductorstore.com/cart/pc/viewPrd.asp?idproduct=50829
Hi. So I did desolder those to use the pads. For test of the booster, I am using a walwart wall plug, 12v 700mA with alligator clips soldered on the wires. Multimeter shows 11.95v from the plug. But I'm not getting any reading on the output. I am looking up more documentation to see what I am doing wrong.OK, so you can desolder the .1 headers on there and use the pads any way you want, or, you can get some Dupont female header connectors and make cables that will plug in.
This kit would allow you to make up two cables that match: https://www.amazon.com/Proster-Crimping-Connectors-0-1-1-0mm²-Connector/dp/B07GS1Z3M3/
by Jake Hertz
by Jake Hertz
by Duane Benson
by Aaron Carman
