Debugging pcb (sun tracker)
DaLyinglama
Joined Apr 20, 2021
in sun tracking pcb using H-bridge to rotate the direction of motor in forward and reverse condition.now forwarding is working but reverse the direction is not working.. continutiy is in between controller and h bridge.
No signal at pin2 when reversing the motor.
Signal present at pin1 in forward conditon
sghioto
Joined Dec 31, 2017
5,392
See if the diode is shorted. If the diode is shorted it will kill the signal coming from pin 72 of the pic. Even though you said you have continuity from the controller to the H bridge is there a signal coming from pin 72 on the pic ?
