I need to glue to a PCB and hotmelt may cause damage by the heat. If I can use superglue that would be great as it would be quick but is it going to cause any problems for the copper tracks?
Cyanoacrylates are commonly used on PCBs to tack bodge wires, and the like. The only possible issue is for contacts which can be coated by vaporized glue if it gets hot before thoroughly cured and that's easy to avoid.I need to glue to a PCB and hotmelt may cause damage by the heat. If I can use superglue that would be great as it would be quick but is it going to cause any problems for the copper tracks?
Yes, how am I going to get on with a PCB glued to my hand?Just be very careful, a very little goes a long way.
I use Loctite 444 all the time for PCB repairs. It's got a bottle of instant hardener.I need to glue to a PCB and hotmelt may cause damage by the heat. If I can use superglue that would be great as it would be quick but is it going to cause any problems for the copper tracks?
Proper cyanoacrylate systems have an accelerator with them, this is the right stuff to be sure.I use Loctite 444 all the time for PCB repairs. It's got a bottle of instant hardener.
https://www.henkel-adhesives.com/us/en/product/instant-adhesives/loctite_444.html
https://forum.allaboutcircuits.com/threads/board-burns.153544/post-1612930
Yes, that can be a problem. Small quantities and careful storage helps. I also put the date I receive stuff on it so I have some idea how fast I am using it. The accelerators work with any instant cyanoacrylate cement and last indefinitely, you can by those little one-time use packages of the glue and get good results.The trouble is, I buy something for a job then don't use it again for a long time. When I come back to it is has set solid,
by Aaron Carman
by Aaron Carman
by Jake Hertz
