IR LED from TV Remote
Alessandro Marchei
Joined Apr 21, 2020
10
Good morning,
I am building a project using IR LED to communicate with a vs1838 IR sensor via NEC protocol.
I studied very well the circuitry of a simple tv remote control and I am wondering why the sensor reads the signal from my LED only if it's just 2-3 meters away from it and while looking straight at the receiver. Insead, if I use the remote, it seems that it can send data from every angle and every distance .. also 10meters or more.
Supposing my code generated from arduino to emulate the NEC protocol (at 38 kHz frequency)is correct (and it does), what could be the problem?
I am driving the LED with a npn transistor (as in the remote control) at 40-50 mA of current, which I think is fair enough.
Why is it so hard for my led to communicate with the sensor? Any advice?
Thank you in advance.
PS : Could it be that tv remote controls have an optimal shape at the emitter, so that the beam is spreaded all over the directions?
https://ak.picdn.net/shutterstock/videos/10017164/thumb/1.jpg
hexreader
Joined Apr 16, 2011
581
Wild guesses only.....
1) 50mA may be insufficient unless that is the average current - some IR LEDs can cope with 1A peak and 100mA continuous. (show your schematic)
2) Inaccurate current measurement - how are you measuring?
3) Inaccurate protocol timings (poor coding) - (show your code) - "learned" timing may not match original timing
4) Slow switching - edges should be square, rounded off edges could in theory reduce reliability - (show your schematic)
5) something else I have not thought about
ericgibbs
Joined Jan 29, 2010
18,879
If you have a mobile phone with an inbuilt video cam, you can compare the apparent brightness of the Remote and the Arduino Remote LED’s.
In a darken area with a low ambient light level, cover over the phone camera lens,with your hand and point the Remote at the camera lens and press a button on the remote, you should see a the LED flickering, do the same for the Arduino remote and compre the LED brightness.
Most mobile phones are able to detect the IR signal.
E
Alessandro Marchei
Joined Apr 21, 2020
10
Sorry but now I cannot share schematics or code, but I think the major issue could be the current at 99%.. in the tv remote the driver is composed by a npn transistor with the LED at the collector, the base connected to the output pin from the microcontroller, and the current limiting resistor is placed at the emitter with just 4 OHMs.. Assuming 3V power supply, the current at the collector should be at least 80 mA, quite a lot
So now I have to try to increase the amount of current and let's see..
Alessandro Marchei
Joined Apr 21, 2020
10
E
Thank you for the advice.. this evening in absolute darkness I will try to compare the brightnesses with my phone.. but it seems they are pretty the same if checked in a luminous room..
ericgibbs
Joined Jan 29, 2010
18,879
hi AM,
Let's know how it goes, I would say that 100mA would be the correct current level for the LED.
Are you using the Arduino 5V to drive the LED. Resistor> NPN.?
Post a sketch.
I used a Nano to make a universal remote, works fine.
BTW: you can pass the NEC code from a laptop to the Arduino, write a simple PC program to do that, and then it is possible to create some novel features.
Simple Sketch:
C-like:
/* SKY
  IR Transmitter Demonstration 1
  IR-Xmit-Demo1.ino
  Control TV using IR Library
  IR LED must use Pin #3
// Include IR Remote Library by Ken Shirriff
#include <IRremote.h>
String cmdSKY = "";
String rxdString;
boolean rxdEOL;
// Define a variable for the button state
int buttonState = 0;
// Create IR Send Object
IRsend irsend;
void setup()
  Serial.begin(38400);
void loop(){
    if (rxdEOL) {
  Serial.print(rxdString);
  cmdSKY= rxdString.substring(2,1);
 for (int i=1; i <4;i++){;
 if (cmdSKY=="P"){
    irsend.sendRC6
    (0xC00C24, 24); //
    delay(100);
 if (cmdSKY=="R"){
    irsend.sendRC6
    (0xC00C3E, 24); //
    delay(100);
if (cmdSKY=="D"){
    irsend.sendRC6
    (0xC00C21, 24); //
    delay(100);
if (cmdSKY=="U"){
    irsend.sendRC6
    (0xC00C20, 24); //
    delay(100);
 if (cmdSKY=="F"){
    irsend.sendRC6
    (0xC00C28, 24); //
    delay(100);
    //  Serial.print(inpString +"...");
   //  Serial.println(sync);
     rxdString="";
     cmdSKY="";
     rxdEOL = false;
     Serial.println("*" + rxdString);
void serialEvent() {  // Master Event
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
     // add it to the rxdString:
     rxdString += inChar;
   if (inChar == '\n') {
  rxdEOL = true;
