it still doesn't work.I think you have the power supplies to the '741 reversed. Should be positive to pin7 and negative to pin 4.
No, it doesn't oscillatesJust to check, replace R1 with a fixed 100k and replace J1 and R4 with a fixed 47k and make sure it oscillates.
It's just a simulation. Maybe I'm doing something wrong.That circuit should definitely oscillate so something else is wrong.
Is this circuit only in a simulator or is it a real circuit?
If it is a real circuit then you probably need a new '741 after the reversed power.
Yes, I corrected that, but still not workingV8 looks odd. It has a line through the middle of it. Just make sure it is connected correctly.
Yes you are right. But it still doesn't work. I also attached the diagram that I saw in a textbook and I don't realize what is wrongWell. that took me a long time to spot. You have the op-amp inputs the wrong way round.
Mine is still not workingHere is the output shown by LTspice for the 100k/47k version. Does yours still not work with those values?
I tried with your circuit..still not working
R7 should be 100k.I tried with your circuit..still not working
you're right. but the output it's still only in 10VR7 should be 100k.
by Jeff Child
by Duane Benson
by Jake Hertz
by Jeff Child
