ir sensor identification
dansteely
Joined Feb 26, 2017
37
Hi All,
I use small 44 key remote controls & receivers for controlling RGB LED strings.
I'd link to identify what kind of IR receiver they are so I can order some separately for experimentation.
Looking on my local suppliers website I note that they are available using different carrier frequencies (56/50/38 & 36 kHz)
Using a scope, how can I identify the frequency of my LED string controller?
Many thanks.
AlbertHall
Joined Jun 4, 2014
12,347
In my experience, they are pretty much interchangeable.
Too see the frequency on a scope you must look at the voltage on the transmitter LED.
Bernard
Joined Aug 7, 2008
5,784
If you can find a point where signal can be viewed with scope, measure the period. 1/ period = frequency; 1/ .00000277 = 36kHz.
dansteely
Joined Feb 26, 2017
37
Thanks both. I've worked out that it's a 38kHz (TSOP4138 equivalent)
On the scope, when I capture the waveform (sorry no screen grab or measurements to hand) there is a long pulse followed by a much shorter one.
No mater which button I press on the remote control the waveform appears the same.
Using on-screen calipers, the waveform durations measure the same.
What am I missing?
Bernard
Joined Aug 7, 2008
5,784
The output from the TSOP4138 has already been demodulated, might go back to transmitter or
use a photo transistor as an emitter follower. Will need IR wavelength to select IR sensor.
950 nm.
dansteely
Joined Feb 26, 2017
37
As with everything in electronics & life, the more you look the more you see.
It's got my interest going and i've got a few photo diodes (SFH213) in my CPC shopping basket so I can see the raw data vs the demodulated output.
EEVBlog Dave did an interesting video covering this stuff. Link
Many thanks for your help.
