Hi there,
Not sure if this is the right area of the forums to ask this, but this is a music related question. Electric violins work through "pick ups", which are transducers, right? Please correct me if I'm wrong. Can we have a transducer that only picks up some harmonics of the Fundamental pitch, instead of all of them? There are some digital plugins that we can have on the computer that analyze the digital signal, execute pitch detection, then it locates the harmonics and you can choose to remove some of them if you like; the problem with this is that it causes some latency, as the harmonic removal is being done after the signal has been released. So can we instead have a transducer that does this at the source, only picks up some over others?
