I thought this may be of interest...
My GN2 fell out of my pocked onto the concrete.
I was less then pleased!
It still works, so I thought I'd try masking it off and spraying it with clear varnish to hold all the glass bits together.
Getting an even coverage was a problem as the spray was beading, even after the screen was cleaned with Acetone.
It looks like it may be successful.
The case it had just perished and fell to bits. This cover is not available as the phone has an extended battery so standard cases do not fit.
I'll try to draw a new one and 3D print it in flexible filament.
This will be interesting to see how it holds up.
