Good evening.
Please advise a circuit for a preamplifier (low noise) of an audio signal from a headset (two set)?
Thank You.
Thank You.
R3 - ?My simulation uses R4 to represent the impedance of an electret mic parallel with the 10k resistor that powers it.
For example, which opamp?Use a low noise audio opamp instead.
You might not need your input opamp. Texas Instruments has a page full of low noise audio opamps.For example, which opamp?
It is the wires in and feeding the amplifier, not the headset that picks up hum. A wire carrying a low level signal needs a shielded audio cable to block hum pickup.There is no hum when connecting this headset to other industrial equipment. It's not about the cable.
