I have 12 C7 bulbs wired 4 on 3 lines feeding from 1 AC line. I am turning each set of 3 bulbs ON or OFF using 4 SS Relays and a Arduino UNO controls the relay triggers. The problem is the bulbs are just a little to bright. So I used a motor controller to lower the AC voltage to get the look I wanted. I then unplugged the lights and measured the AC voltage coming out of the controller. 98.5 VAC to be exact. So I would like to drop the voltage close to that.
What would be the best way to do that? Dimmer switch maybe? Open to suggestions. Thanks
