I am new to this forum and a novice, so take it slowly. I have received much help previously on a bench power supply query, this query is along the same lines. I have been away from this site for a while but I have continued experimenting on breadboards with op-amps during this time.
I am using a 741 op-amp and I know a lot of people don't like this old chip but I am using it because I have many and if I break one, it's not a problem and it seems to work ok for my requirement at the moment ie. learning about op-amps.
I built a power supply previously using an op-amp in an Non-Inverting Configuration using a single rail supply of 23v, I had a voltage drop problem which I solved with the help of people on this forum, happy days!.
I was still confused about powering an op-amp with a dual supply, why go to the trouble (I know for audio you use both + and - waveforms). I now know if I want to lower the voltage down to zero, I need a negative rail.
I don't have a centre tapped transformer with @15-0-15v output. I read about using an op-amp to create a virtual ground, I seen circuit marked "A" online which outputs enough current to power circuit "B", it does work.
The pot P1 sets the + or - balance.
My question:
When I power the virtual ground op-amp with a 30v supply, I can set P1 to balance the rails very evenly or unevenly.
If I balance the output +15v -15v (slightly under this), I get a very limited range output in "B" circuit.
If I set the output to a very uneven output +17v -12v I get a an increased range in "B", regulation is good to about 12v.
I know the 741 is limited to 30v +/- 15v, but this 30v, can it be so heavy unbalanced?.
I have noticed if I go further and unbalance it more, +20v -10v, there is nothing to be gained, it peaks at around 12v, so is the max for the 741, 30v/2=15v minus 3v( as close as it can get to the rail) =12v?? or have I got this completely wrong?.
My question:
