using linear regulator in high voltage with pre-regulator
Status
Not open for further replies.
johny_fv9a
Joined Feb 19, 2021
My structure is like this:
0-220 Vac——>full wave rectifier——>linear regulator——>microcontroller and led
Microcontroller and led are taking 20ma.My linear regulator is LD1086.Regulator can accept input voltage up to 30V.I dont want step down transformer.I need to pre regulator.And I need to 5V output without ripple in regulator.Can you help me?
dendad
Joined Feb 20, 2016
4,471
If this is directly connected to the mains, that is a very dangerous way to go. And it is against this site's rules I think.
Why do you not want to use a transformer?
An old cell phone power supply would work very well, and be a LOT safer.
DickCappels
Joined Aug 21, 2008
10,169
Direct connection to the mains is ok according to the User Agreement, and discussion of the same is allowed provided everything in done safely.
I agree an USB charger or cell phone charger would be a much better way to go because all of the safety work has already been done by professionals. I use such chargers often -my objective is not to build yet another power supply.
34,408
I agree with the above.
No reason to mess with the dangerous main's voltage without isolation when 5V wallworts are so common (and inexpensive if you have to buy one).
shortbus
Joined Sep 30, 2009
10,045
When did this change? It, getting low voltage with out isolation, used to be forbidden here, and many threads were locked about doing it. As far as "provided everything in done safely", the TS hasn't proven that he can do it, since this is his first post.
Papabravo
Joined Feb 24, 2006
21,225
This policy changed at some point after the forum was acquired. It was at about the same time as automotive topics were allowed, I want to say 2017-2018 time frame.
dl324
Joined Mar 30, 2015
16,909
I don't know when or why it changed either, but I won't offer assistance in any threads with mains connections without isolation.
johny_fv9a
Joined Feb 19, 2021
because this is variable voltage.between 0-220Vac.also,why dangerous?I need to pre regulator
dendad
Joined Feb 20, 2016
4,471
What is your actual supply device and voltage range?
Is it the mains or a generator?
It is really hard to get 5V out with 0V in!
A "universal" mains input power supply, like most phone chargers, will work from a wide input voltage range.
And any voltage over about 50V can be dangerous. I'm particularly concerned as it sounds like you do not have much experience in electronics, and so you are dealing with potentially lethal voltages so you could quite easilly hurt yourself, or maybe worse, someone else.
Please, post more details of your project if you really want assistance.
Papabravo
Joined Feb 24, 2006
21,225
Because line voltage can KILL you! Do you fancy being the winner of a Darwin Award?
The pre-regulator is not the way to go. It is too inefficient and you will be dissipating quite a bit of heat. What you want is an offline SMPS that goes straight to +5V
You wont be able to generate +5V from 0 VAC as has already been mentioned. In any SMPS you can reduce the ripple to undetectable levels with excellent transient response. This is not a good project for a beginner, so it might be best if you purchased a unit suitable for your needs.
DickCappels
Joined Aug 21, 2008
10,169
The policy was changed a few months ago. The discussion revolved around the question of whether it was better to refuse to help novices dabbling in non-isolated power supplies or to help them do so safely.
Deleted member 115935
Joined Dec 31, 1969
Regarding the advise and questions we ask on here,
if some one gives advise, and the user is injured,
what is our liability as posters ?
bertus
Joined Apr 5, 2008
22,276
The User Agreement has been changed.
The restricted topics and safety rules have been split:
When the safety comes into play, we are allowed to close the thread with section 7 of the UA.
Bertus
Status
