What about using a d flip flop? I have a sn74hc574n on hand as well as a bunch of logic CMOS chips.. nand, inverters etc.No. You need a 74HC74 or 4013.
I'm going to build a jk out of nor gates, looks like it will take 8 gates on two 74hc02 chipsYou need a D-type flip-flop with a notQ output (such as a 4013 or 74HC74). A 74HC574 is a D-type flip-flop, but has no notQ output.
I got it to work but I'm having bouncing problems, I tried a few different ways of pulse detection and even a clean pulse from a 555 in monostable as well as a clock signal (which it lags behind or sometimes not at all) still bounces regardless of the pulse duration, so it seems to be an instability in the nor network somewhereI presume the design you'll use is exactly what is in a 4027 or 74HC73 etc. so I don't see why it shouldn't work.
I could have a JK flipflop in my mailbox tomorrow morning, and it would take me longer than that to wire up 8 nor gates!
Apologies for not being helpful!
Sure. When the 555 is triggered what does the output state need to be high or low?How can I use a 555 as a T flip flop? It needs to toggle at the rising edge of an input that will be active high for 1 hour then active low for 11 hours
A 555 can produce a frequency of 0.000023Hz with a 8.3% duty?Sure. When the 555 is triggered what does the output state need to be ,high or low?
If you show us the "crude design" you are using, we could better answer that question.Any drawbacks to this crude design?
Not sure how that happened. Everyone, I’ve deleted the confusing post and recreated one with my intent.What's irrelevant, your previous post or mine?
Because the design constraints of the circuit (0.000023Hz at 8.3%) is unrealistic. You won’t be able to use a 555, so it’s output state is irrelevant.OK, so why is the output state off the 555 irrelevant when triggered?
That’s a valid interpretation. Let’s confirm it. I’m not as confident as you that that is what he means.The TS wants to use the 555 as a FF not an oscillator.
It's the trigger pulse that will be high for 1 hour then low for 11 hours is my take.
TS stated "rising edge of an input that will be active high for 1 hour then active low for 11 hours"
OK, yes, looks like I overlooked that part of it. That's what happens when I don't pay enough attention.The TS wants to use the 555 as a FF not an oscillator.
Thread starter | Similar threads | Forum | Replies | Date |
Transistor Toggle Flip Flop | General Electronics Chat | 17 | ||
Dual comparator toggle flip-flop. | General Electronics Chat | 23 | ||
T Is for Toggle: Understanding the T Flip-Flop | AAC Contributors Forum | 0 | ||
S | D-Type flip flop for toggle. Slap-a-duck | Digital Design | 31 | |
M | Why is this toggle flip flop does not work ? | General Electronics Chat | 13 |
by Jake Hertz
by Duane Benson
