Hello all,
I am designing a PCB that contains some relays, so I decided to use cutouts to separate relay's contacts (depicted by green in image below) and maybe Neutral/line based on what I have seen in some PCB designs...
my questions are: what is the purpose of cutouts/slots other than separating high voltage from low voltage!? I mean what other cases that cutouts might be useful? and how to determine the shape and size of cutouts in each case?
Also I decided to use cutouts to make a line that separates power supply from digital circuit (depicted with blue)? is this really necessary and if this might affect board strength!?
Thanks,
Thanks,
