I am making a project where in I am connecting few LEDs with my STM8 Discovery Board (PA3, PD3, PD4) and setting the mode using the on-board button (PB7). The issue I am facing is that I am able to toggle to Flag = 2 (with for loops for phasing the 3 LEDs) but the button becomes unresponsive after that. I need to be able to go back to Flag 0 and Flag 1.
I am a beginner so there is a lot of hit & trial that I have done but the code is doing what it is supposed to do except this part. Would appreciate any guidance on this pls.
TIA!
TIA!
IAR STM8 Code:
#include "STM8S.h"
void clock_setup(void);
void GPIO_setup(void);
void ADC1_setup(void);
void TIM2_setup(void);
void Key_scan(void);
unsigned int A0 = 0x0000;
int i = 0;
int flag = 0;
void delay_ms(long n)
while(n--> 0);
void main()
clock_setup();
GPIO_setup();
ADC1_setup();
TIM2_setup();
//ITC_setup();
while(TRUE)
Key_scan();
CLK_DeInit();
CLK_HSECmd(DISABLE);
CLK_LSICmd(DISABLE);
CLK_HSICmd(ENABLE);
while(CLK_GetFlagStatus(CLK_FLAG_HSIRDY) == FALSE);
CLK_ClockSwitchCmd(ENABLE);
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
CLK_SYSCLKConfig(CLK_PRESCALER_CPUDIV1);
CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO, CLK_SOURCE_HSI,
DISABLE, CLK_CURRENTCLOCKSTATE_ENABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_SPI, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_I2C, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_ADC, ENABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_AWU, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_UART1, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_TIMER1, DISABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_TIMER2, ENABLE);
CLK_PeripheralClockConfig(CLK_PERIPHERAL_TIMER4, DISABLE);
GPIO_DeInit(GPIOB);
GPIO_Init(GPIOB, GPIO_PIN_0, GPIO_MODE_IN_FL_NO_IT);
GPIO_DeInit(GPIOA);
GPIO_Init(GPIOA, GPIO_PIN_3, GPIO_MODE_OUT_PP_HIGH_FAST);
GPIO_DeInit(GPIOD);
GPIO_Init(GPIOD, GPIO_PIN_3, GPIO_MODE_OUT_PP_HIGH_FAST);
GPIO_Init(GPIOD, GPIO_PIN_4, GPIO_MODE_OUT_PP_HIGH_FAST);
GPIO_DeInit(GPIOB);
GPIO_Init(GPIOB, GPIO_PIN_7, GPIO_MODE_IN_FL_NO_IT);
TIM2_DeInit();
TIM2_TimeBaseInit(TIM2_PRESCALER_32, 1000);
TIM2_OC1Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE, 1000,
TIM2_OCPOLARITY_LOW);
TIM2_OC2Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE, 1000,
TIM2_OC3Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE, 1000,
TIM2_Cmd(ENABLE);
ADC1_DeInit();
ADC1_Init(ADC1_CONVERSIONMODE_CONTINUOUS,
ADC1_CHANNEL_0,
ADC1_PRESSEL_FCPU_D18,
ADC1_EXTTRIG_GPIO,
DISABLE,
ADC1_ALIGN_RIGHT,
ADC1_SCHMITTTRIG_CHANNEL0,
DISABLE);
ADC1_Cmd(ENABLE);
void Key_scan(void)
if(GPIO_ReadInputPin(GPIOB, GPIO_PIN_7) == 0)
do
}while(GPIO_ReadInputPin(GPIOB, GPIO_PIN_7) == 0);
//delay(10000);
delay_ms(1000);
if(flag > 2)
flag = 0;
else
flag = flag + 1;
if (flag == 0)
TIM2_SetCompare1(0);
TIM2_SetCompare2(0);
TIM2_SetCompare3(0);
if (flag == 1)
ADC1_StartConversion();
while(ADC1_GetFlagStatus(ADC1_FLAG_EOC) == FALSE);
A0 = 200 * ADC1_GetConversionValue();
ADC1_ClearFlag(ADC1_FLAG_EOC);
delay_ms(50);
TIM2_SetCompare1(A0);
TIM2_SetCompare2(A0);
TIM2_SetCompare3(A0);
delay_ms(50);
if (flag == 2)
for(i = 0; i < 3000; i += 1)
TIM2_SetCompare1(i);
delay_ms(100);
delay_ms(10);
TIM2_SetCompare2(i);
delay_ms(100);
delay_ms(10);
TIM2_SetCompare3(i);
delay_ms(100);
delay_ms(10);
for(i = 3000; i > 0; i -= 1)
delay_ms(100);
delay_ms(10);
delay_ms(100);
delay_ms(10);
delay_ms(100);
delay_ms(10);
