Hi, thanks for accepting me to the forum.
I have a question that I would like some advice with.
I am modifying a Hella Intellivision module for cornering lights and want to keep the number of wires down that need to pass through the bulkhead.
I have already externalised the gyro module to a smaller unit to fit on the internal vehicle bulkhead (its a Land Rover Defender with very limited space) and am ready to commence installation and I don't want to blow the module!
The two front fog lights are connected by a 4 way multi plug. The indicator lights (used as turn sensors) are connected with another multiplug.
My assumption - there is no need to run 4 separate -ve wires.
Why do I want to do this? Because a clump of 8 power wires is substantial in this install. 4 or 5 is a signifcant reduction.
How can I validate this assumption or am I mad to try?
Investigation shows that there is zero resistance between the -ve wire connection points on the multiplugs.
Fundamental question is - can I connect all to one -ve to go through the bulkhead and/or do I even need to separate them again or apss them through the bulkhead? Can I just connect to chassis which is -ve earth inside the vehicle and rely on the individual units being earthed in the engine compartment connected to chassis? They are all operating at 12v.
The manufacturer has declined to answer my emails :-(
