Hi everyone, This is my homework. I have to do heartbeat monitor and it needs to count up to 99 then stays. I designed the circuit and simulated works perfectly. I used Proteus software for the simulation, but in Proteus CD4026's Carry Out (5) pin is only 0 at 9 so I designed for this situation to detect 99 as you can see from schematic. But I have CD4026BE in circuit implementation and its datasheet says Carry out pin is low at 5-6-7-8-9 counts then I tried to detect 9 from decoder parts (A-B-C-D-E-F-G) to detect 99 but whenever I connect the output of decoder parts with AND gates (CD4026- A-B-C-D-E-F-G) displays are turning off due to low voltage output. I thought I need to use OPAMP for amplification the voltage but it didn't worked aswell. Can you help me please? btw In the first version of the implementation it is working but stays at 55 because carry out pins are low at 55. Second screenshot is for U3:B in first schematic. I tried to sense 99 from decoder outputs.
