First of all, this is a 600W electronic ballast that is garbage because of the burnout. I only want to try and fix this just to see if I can. Nothing important, just a fun skill testing exercise for myself and that's it.
That being said, is it possible to repair this damage and replace the resistor and get it working again?
It doesn't look like it's burned through the entire board, and I'm just about to check the other side after this post, but I thinking I could use a spot of epoxy to fix the "crater" and just drop in another resistor of the same value?
Attached are pictures of the damage, and a functional part. The entire board is covered in this rubbery grey stuff that picks off pretty easily....what is it?
