What does "inductive loads must be diode suppressed" mean and what diode should I try?
daytona
Joined Jan 15, 2021
41
I need to incorporate an optic level switch in a radiator tank to determine when the water level drops low. The paper that came with the Gems sensor says "inductive loads must be diode suppressed" what does that mean and what diode should I try? They give a schematic that shows SENSOR WIRING.jpg
30,824
A coil of wire, a solenoid or motor for example, is an inductive load.
When current flows in an inductive load a magnetic field is generated. This represents energy.
When the current through the inductor is removed (i.e. driver or switch is turned off) the magnetic field collapses and the stored energy has to be released somewhere. This results in a large reverse voltage (back emf) across the coil of wire. This voltage spike can cause havoc in electronics and may even destroy your electronics. A diode (snubber circuit) is placed across the inductive load or across the active driver in order to suppress the back emf.
If your application is not switching an inductive load then you can omit the snubber diode.
MaxHeadRoom
Joined Jul 18, 2013
28,702
Gems sensors often are used to pick up a relay, if this is the case with yours, then you need it.
They usually are reed relay style switching devices.
Max.
daytona
Joined Jan 15, 2021
41
Thanks, I don't think it is an inductive load. It goes into an engine controller switched input.
MaxHeadRoom
Joined Jul 18, 2013
28,702
The Gem sensors I have used generally have used a PM magnet in the float and reed relay style switch, this will not require a BEMF diode, only in the case of the switch operating a relay, then the diode is needed.
Max.
daytona
Joined Jan 15, 2021
41
Max.
Thanks, it not a float. Ours is an opto device with open collector output of 18 mA sink max installed in the radiator. I think the engine controller is not an inductive load. I do have a dual float in the fuel system and it is just two switches
MaxHeadRoom
Joined Jul 18, 2013
28,702
OK, then if it inputs into a semiconductor circuit, Opto IC etc, then the diode is not needed.
Max.
