I can't get this into my thick skull. If this is correct please enlighten me.
If you measure across the power supply you get 30V so the 100Ω resistor should be seeing 30V? Except that the Zener is dropping 20V across it. Does the power supply never reach 30V? Does that 10V magically disappear?
I get the load part but having a hard time understanding only 10V across the 100Ω resistor...
