I am currently reading the book "The Art of Electronics 3rd Edition". However I am having some difficulties to understand chapter "3.4.1 FET analog switch". This section is about how MOSFETs can be used for switching analog signals. As an example the attached circuit diagram (Fig. 3.59) is used.
However, some details confuse me about this circuit.
1. Source and drain of the MOSFET are not tagged. It seems as if the "signal in"-terminal can be drain as well as source. This makes it difficult for me to analyse/understand the circuit behaviour.
2. In nearly all examples the substrate and the source are shorted. In this case however, the substrate is directly connected to ground. Normally the Gate-Source voltage \(V_{GS}\) controls the current flow \(I_D\). But does that still hold in this case? As far as I know, the Gate-substrate voltage \(V_{GB}\) controls how many charge carriers can flow under the gate (Inversion, see second attached image). This is due to the electric field which attracts minority charge carriers of the substrate to the gate so that a conducting channel is formed. Normally the gate-substrate voltage is equal to the gate-source voltage because they are shorted. But in this case, they are not equal. Therefore I suggest, that the current flow is not controlled by \(V_{GS}\) instead \(V_{GB}\) should be the important voltage. But am I right here? Most google results suggest that my opinion is wrong, however I don't understand the exact reason.
The authors write a few statements that I do not understand. Maybe due to the preceding understanding problems.
1. "the gate signal is not at all critical, as long as it is sufficiently more positive than the largest signal (to maintain \(R_{On}\) low)"
Why should the magnitude of the signal matter? If the \(V_{GB}\) voltage controls the channel, the gate-drain voltage should be irrelevant. Maybe the authors want to point out that the FET should be in the linear region (low \(V_{DS}\) voltage drop) for a small \(R_{On}\)? However, I have not been able to derive a formula for \(V_{DS}\) from the given circuit diagram. Therefore, I don't understand how \(V_{DS}\) and the signal voltage are connected.
2. "negative signals would cause the FET to turn on with the gate grounded"
Why should that be the case? Of course, negative signal voltages make the body diode between the "signal in"-terminal and the substrate conducting. That is definitely undesirable. But I don't see why negative signal voltages should somehow lead to an inversion effect in the semiconductor under the gate. So it shouldn't turn on as far as I think.
I would be grateful if somebody could help me with this issue
Best wishes and merry christmas
PS: I have already asked this question here. Sorry for cross posting this question on two boards, but the present answers are not very helpful for me... Maybe someone in this forum knows a good explanation who wouldn't browse on Stack Overflow.
