Hi Everyone,
I am extremely green to the electronics world, and as such I am looking for direction on a new project.
I need to drive a DC motor clockwise 45 degrees, then counterclockwise 45 degrees repeatedly for a period of approximately 3 seconds, then dwell for 3 seconds, then repeat. I'd like to use a 6 or 9V power supply and the motor run sequence should simply be controlled by an on/off switch. Motor speed must run at approximately 200RPM.
What would be the simplest/cheapest method for controlling this motion sequence?
Are there any concerns regarding motor longevity?
