Dear All Members,
I am facing issue of Failure of 200V, 5W Zener Diode (1N5388B) connected across primary winding of transformer in SMPS TOP 224Y based design. Switching frequency of Power supply is 100 KHz. When tested Zener for failure issue i observed that it is heating more then 60Deg. C but less then 75Deg. C. in just 30sec. I have done some trials for finding cause,
1. Current through Zener measured is 7mA which is less then 23.6mA mentioned in datasheet.
2. Changed voltage rating of Zener by replacing with another Zener diode with higher voltage rating of 270V, but that too is heating.
3. During this i observed that Transformer is also heating too much. Transformer used is E30/15/7, 12Pin horizontal.
4. Leakage Inductance when measured at primary by shorting all secondary is found around 140 Micro H. Primary inductance when all secondary open is measured to be 3.563mH, this was measured by LCR meter at 25KHz.
5. Supply is designed for Universal Input (85VAC - 265VAC), but it is not switching On below 110VAC. Below this Zener gets blown.
Power supply is designed for 6W and 80% efficiency.
The only change in our supply and that mentioned in application note of power integration if the use of Zener, In there application Note AN 22 they mention TVS diode of rating 200V and we are using Zener diode of 200V.
It is also not that all the instruments are failing but the failing rate is about 10%, so it is of concern to us.
Please help.
Regards,
Shashank
Please help.
Regards,
Shashank
