Choice of resistor and capacitor for low-pass filter
Hendrik Bleus
Joined Feb 22, 2017
Hi folks!
I have a PIC microcontroller which is generating a PWM signal of 5 kHz. It has a varying dutycycle so I can draw an analog signal, which has to be smoothened. For that I need a low-pass filter, but I dont know which values to pick for R and C. Can you guys help?
If you need more info, feel free to ask!
Papabravo
Joined Feb 24, 2006
21,227
It sounds like you want a steady DC value from a PWM with a period of 200 μsec.
You should choose a corner frequency for your RC filter at a frequency that is a maximum of 10% of the PWM frequency. So 500 Hz. would be the maximum corner frequency.
You want to choose the resistance R and the capacitor with reactance Xc, such that the Xc is equal to the resistance at the corner frequency.
Example: suppose the resistance, R should be 150 Ω. Then Xc would be 150 Ω @ 500 Hz.
Therefore:
\[ C\;=\;\frac{1}{2\pi \cdot 150 \cdot 500}\;=\;2.12\mu \text f \]
You then look for a capacitor you can use and see that 2.2 μf is a standard value.
If you want you can recompute the reactance of the 2.2 μf capacitor ay 500 Hz. and adjust the resistor if required. Since the capacitor is a bit bigger the reactance will be a bit smaller at 500 Hz. so the resistor can be adjusted to a lower value. If this produces acceptable results, then you are done. If not you can shoot for a lower corner frequency. If you need a higher voltage output you can use an operational amplifier to make an active filter with gain to get the required output.
Deleted member 440916
Joined Dec 31, 1969
Ahh I was in the middle of answering and see a better one has appeared above BUT
To avoid loading the PIC to heavily and use a smaller capacitor I suggest you change the above slightly in ratio-metric proportion such as increasing R from 150R to 1K5 and reducing C from 2.2uF to 220nF etc.
Beware the load impedance of what you are using to measure your results :)
Ian0
Joined Aug 7, 2020
9,844
What bandwidth do you require of your output signal? And how much remaining 5kHz can you tolerate in your output signal?
Audioguru again
Joined Oct 21, 2019
6,705
A single resistor and single capacitor make a very simple filter that does not do much.
Many class-D audio amplifiers use a PWM frequency of hundreds of kHz and a digital filter.
Papabravo
Joined Feb 24, 2006
21,227
The problem as stated does not have a unique solution. The TS did not specify any additional information, and I did not assume that this was an application that required a power amplifier. Without any additional information the numbers don't matter, it is the method of arriving at the solution that is important. I did suggest using a different corner frequency. I also suggested an operational amplifier for two reasons:
  1. To make the choice of a specific value of the resistor unimportant
  2. To provide some gain for duty cycles near 100%
With a Vcc for the PIC of 3.3V driving 300 Ω you need 11 mA. That doesn't seem like it would require a power amplifier. What have y'all been smoking?
Yeah..OK. He didn't specify a load impedance either.
Joined Dec 31, 1969
Lolo I think the OP said a PIC and I don't recall them talking about class-D at all..... Chinese whispers hahaha
Audioguru again
Joined Oct 21, 2019
6,705
He said for an analog signal which might be a sub-woofer class-D audio signal. Wouldn't the very low PWM of 5kHz make a very noisy or slow reacting motor speed controller?
Ian0
Joined Aug 7, 2020
9,844
Output impedance of a PIC is about 40Ω, so whilst it can drive 300Ω there will be quite some signal loss.
34,464
There is going to be substantial insertion loss from a passive filter regardless of any other consideration.
That's what you want.
Significant insertion loss for the PWM frequency, but little insertion loss for the modulating frequency (which has not been established).
Papabravo
Joined Feb 24, 2006
21,227
The insertion loss affects the entire passband including the modulating frequency for a single RC stage.
Required voltage levels have only been implied, not explicitly stated so it is a bit difficult to satisfy a set of unspecified requirements.
