Hey, im just wondering if I can get a quick hand with connecting this fan:
https://www.jaycar.com.au/120mm-240v-standard-fan/p/YX2514
To mains power.
To mains power.
yeah we have 240 AC, so therefore i can just get any fused plug and strip it then connect to + and - of the fan?hi M,
Is your local mains supply 240V AC.?
You need to connect tt the mains socket using a fused plug.
E
So if I strip a say PC power supply cable then connect to positive and negative of the spade sockets, then connect to mains this should work??hi M,
The datasheet states spade terminals, usually spade sockets are fixed to the end of the mains wires and then pushed on the spade terminals.
You can solder the wires directly to the spade terminals, if you don't have the mating sockets.
Fuse it at approx 3Amp.
E
So I would stripe the twin mains wire off a mains plug and solder line and neutral to the fan spade terminals?hi,
The 240V AC mains supply and fan are Line and Neutral , not + and -.
Connection:
Wall mains socket >> fused mains plug >> twin mains wire >> Fan spade terminals.
E
Note: ONLY twin mains wire between Mains Plug and Fan, nothing else in between.
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Aaron Carman
