no i don't.Do you have capacitors on the "load supply" at the MOSFET?
what is the output that you mean? from Mosfet Drain to ground?A small resistor in series with a small capacitor from the MOSFET output to ground should minimize that.
The output to the inductor, which is shown as the MOSFET Source in your schematic.what is the output that you mean? from Mosfet Drain to ground?
No.Would that capacitor reduce the ripple in output voltage, the ripple is high 1.5 v?
No it will reduce the ripple on the input. You need a capacitor close to the MOSFET.Would that capacitor reduce the ripple in output voltage, the ripple is high 1.5 v?
but this will increase stability of the input voltage and i don't want to increase stability by adding capacitor, i increase it by controller designThe output to the inductor, which is shown as the MOSFET Source in your schematic.
The Drain goes to the supply so why would you consider that an output?
why is the ripple high, it should be very small according to calculation , it should be 4.2e-4The ripple seems high. It is a function of Frequency L1, C6 and Rload (R1). The LC makes a low pass filter to reduce the ripple.
I don't know the voltage or current. Increasing C6 will help the ripple. Adding a second cap will cut the ripple to 1/2.
the load draw around 3.5 A while the inductor didn't get hot so i think it is rated. also i reduced the current to 1 A the ripple decreased but not too muchIf the inductor is under rated for current it might be saturating. This will increase the ripple!
No.but this will increase stability of the input voltage and i don't want to increase stability by adding capacitor, i increase it by controller design
by Aaron Carman
by Jake Hertz
by Jake Hertz
