I have a coaxial switch that uses TTL to change the state. Can I use a bench supply to actuate each switch? I am trying to switch each logic condition using +5V for each logic pin I want to turn off and connecting to GND the one I want on. I am looking to check continuity in each position and have had no luck powering up the switch. Could someone please assist?
