I am reading this page:
http://www.play-hookey.com/analog/current_mirrors/active_loads.html
and the circuit is
The Rref and Q3 control the (max) quiescent current through the Q2 as a current mirror.
I guess the current through Q1 collector is manipulated by variations in the base voltage.
1. when base is HIGH, current through Q1 is HIGH, and no current is available for OUT. OUT = Current Sink / Negative Output.
2. when base is LOW, current through Q1 is LOW, and current is available for OUT. OUT = Current Source / Positive Output.
The output seems to be in the form of Current and NOT Voltage.
Is it possible to calculate the OUT voltage in this circuit and the gain ?
Or is it just not applicable in this case, until another stage converts the current output to voltage ?
and the circuit is
