LED Timing Circuit with Single Gate
brightnight1
Joined Jan 13, 2018
91
I'm looking to build a low power circuit with a single gate logic chip to pulse an LED at a certain rate (10Hz) using some resistors, a capacitor, and a diode.I could use a 555 timer but for anyone wondering, I want to do it this way. Is there a name for this type of circuit so that I can look up a reference design? Someone told me I could use the 74LVC1G14SE-7 but I don't understand how to design the circuit:
74LVC1G14SE-7:
https://www.digikey.com/en/products/detail/diodes-incorporated/74LVC1G14SE-7/3829442
Delta Prime
Joined Nov 15, 2019
1,311
Hello there
Here you go.
All you need now is a LED along with its current limiting resistor.You are going to run into a lot of math that looks difficult but it's not, replace the resistor with a 1K ohm potentiometer and the capacitor start off with a one microfarad polarized capacitor with the working DC voltage of 10 volts or higher with the power supply 5 volts.
I hope this helps you.
https://www.allaboutcircuits.com/technical-articles/exactly-how-schmitt-trigger-oscillators-work/
Tonyr1084
Joined Sep 24, 2015
7,905
While generally I'm opposed to solving or designing circuits for others - in part because I'm not that good at it - here's one possible solution. This should give you nearly 10Hz (10 times per second) flash rate. You can adjust VR1 to control the ON time versus the OFF time. Others present on this site will definitely tweak my design or point out errors in my circuit. That's totally welcomed. Depending on the voltage used (5V or higher) and the LED Forward Voltage (Vf) you will need to calculate for the proper resistance. It may look difficult but it's actually fairly straight forward.
Papabravo
Joined Feb 24, 2006
21,228
74LVC1G14SE-7:
It is called a relaxation oscillator.
OOPS -- missed post by @Ian0
You can also use an opamp or a comparator. You get better results with a better capacitor X7R or C0G (NP0)
brightnight1
Joined Jan 13, 2018
91
Thanks for all the replies, I was able to simulate and test a Schmitt trigger oscillator in LTspice which was awesome! Now I realize it isn't exactly what I wanted, or I'm not sure how to make it what I want. I mentioned in my first post that I wanted to blink an LED at 10Hz...
What I should've mentioned is that I want to flash an LED at 10Hz but I only want to turn the LED on for a 1us pulse. I was playing around with the resistor and capacitor values in my trigger and not sure how to accomplish that. If I want a false pulse, that means I need a small cap value so it charges and discharges quickly. If it charges quickly then it will triger again quickly so not sure how to solve that problem.
Can I pick values for a schmitt trigger oscillator design that allow me to blink an LED for 1us at 10Hz with this type of circuit?
Audioguru again
Joined Oct 21, 2019
6,711
A 1us LED pulse might be so quick and dim that you might not see it. I read that 30ms looks as bright as an LED at the same continuous current but shorter durations look dimmed like PWM dims it.
brightnight1
Joined Jan 13, 2018
91
THanks for the reply, I'll be reading it with an IR receiver so not worried about seeing it, just about saving power by keeping the pulse short.
AnalogKid
Joined Aug 1, 2013
11,056
A 1 us pulse at a 10 Hz rate is a 100,000-to-1 duty cycle. For a simple relaxation oscillator with 1 capacitor, this is not a practical design; the two resistors would be something like 1 K and 100 M. Better to separate things into two stages, a 10 Hz squarewave oscillator and a 1 us monostable. This can be achieved with two 74xxx14 gates, two of the NAND gates in a CD4093, or two of just about anything else that has predictable hysteresis.
Because the output pulse is so much shorter than the oscillator period, the 1 us pulse former does nto have to be a true 2-gate monostable with feedback. A simple differentiator (boxcar) circuit will work fine. What is the output current required?
ak
18,609
Hello there
Here you go.
You can use the circuit shown, but use a CD4049 hex inverter, and put the other 5 inverters in parallel to drive the LED. even at 5 volts that will provide enough current to light the LED very brightly, it the inverters are used to pull down the negative side of tyhe LED. the 4049 can sink much more current than it can source.
brightnight1
Joined Jan 13, 2018
91
Awesome, thank you all for the advice I appreciate it!
Danko
Joined Nov 22, 2017
1,836
Current of Ic(Q2) and LED U1 can be adjusted up to 180 mA by resistor R2.
Current, consumed from source 5V is about 4.5uA.
ADDED:
With R3=1MΩ and R4=2MΩ current from source 5V decreases to 2.9μA.
