Hi to all members ,I’m hoping I can find out the answers to my questions on here . Basically I’ve recently purchased a Super73 RX ebike . It’s powered by a rear hub motor in conjunction with pedal as l assist . Being a EU model it doesn’t come with a throttle as std however they are bring one out later this month. This will be for off-road purposes only . The throttle is a thumb type unit and is designed to simply plug into the female bafang type terminal that’s on the bike ready . I would like to use a twist throttle and the one I want to purchase is a Magura 317 .
The description is as follows
Complete throttle grip model 317 Magura
Motokay item number: 3237571
DESCRIPTION OF THE ITEM
This article belongs to the following categories:
Chassis »Vehicle equipment» Magura »Throttle twist grip» Electric throttle grip
Chassis »Steering» Handlebar fittings »Throttle handles» Electric throttle
Glass-fiber reinforced plastic housing for 22 mm pipe diameter. Total length approx. 150 mm, maximum load capacity 1 watt, resistance value and control range of the potentiometer 5 kOhm, control range 0-5 kOhm, cable length 1800 mm. Connection with 3-core cable with an outside diameter of 6 mm.
Rotation angle: 75 degrees
My concern is that my bike from what I’ve been told has a hall sensor so I’m not sure if this throttle will be a simple plug and play affair once I’ve soldered the correct male yellow bafang connector on .
I had read on a postwhen someone had used this throttle on their home brew ebike that they had to solder resistors in to two of the 3 throttle wires to achieve a smooth linear throttle curve ?
I hope some one can help ,and if you need more info please ask . Incidentally this Magura throttle was used on a one off limited edition build of my bike . I’ve added some info on the throttle in question
thanks
Ja
thanks
Ja
