I have a LED PCB attached to a water cooling block, and I want to use several in-series strings within a parallel circuit. There are several kinds of LEDs of different forward voltages that I would like to connect in series this way. Can I do this? As long as each string has the same total Vf? I assume thermal runaway is no issue since water cooling is used? There are about 30 in-series strings
