Hello , in the example code bellow we have NVIC_ClearPendingIRQ(USART0_TX_IRQn);
which from page 220 in the manual enables USART_TX interrupt.
But later on in teh code we have
Which means enable the enable the TXBL flag.
So it seems we are anabling the same thing twice,
What is the difference between the two enables,why do we need to enable twice?
https://www.silabs.com/content/user...earmcortexm4manualih-jZ8g/Cortex M4 Guide.pdf
Code:
// Enable transmit buffer level interrupt
USART_IntEnable(USART0, USART_IEN_TXBL);
Code:
#include "em_device.h"
#include "em_chip.h"
#include "em_emu.h"
#include "em_cmu.h"
#include "em_gpio.h"
#include "em_usart.h"
#include "bsp.h"
// Size of the buffer for received data
#define BUFLEN 80
// Receive data buffer
uint8_t buffer[BUFLEN];
// Current position ins buffer
uint32_t inpos = 0;
uint32_t outpos = 0;
// True while receiving data (waiting for CR or BUFLEN characters)
bool receive = true;
* @brief
* GPIO initialization
void initGpio(void)
CMU_ClockEnable(cmuClock_GPIO, true);
// Configure VCOM transmit pin to board controller as an output
GPIO_PinModeSet(BSP_BCC_TXPORT, BSP_BCC_TXPIN, gpioModePushPull, 1);
// Configure VCOM reeive pin from board controller as an input
GPIO_PinModeSet(BSP_BCC_RXPORT, BSP_BCC_RXPIN, gpioModeInput, 0);
// Enable VCOM connection to board controller
GPIO_PinModeSet(BSP_BCC_ENABLE_PORT, BSP_BCC_ENABLE_PIN, gpioModePushPull, 1);
* @brief
* USART0 initialization (VCOM on xG1/xG12/xG13 boards)
void initUsart0(void)
CMU_ClockEnable(cmuClock_USART0, true);
// Default asynchronous initializer (115.2 Kbps, 8N1, no flow control)
USART_InitAsync_TypeDef init = USART_INITASYNC_DEFAULT;
// Configure and enable USART0
USART_InitAsync(USART0, &init);
// Enable NVIC USART sources
NVIC_ClearPendingIRQ(USART0_RX_IRQn);
NVIC_EnableIRQ(USART0_RX_IRQn);
NVIC_EnableIRQ(USART0_TX_IRQn);
USART0->ROUTEPEN |= USART_ROUTEPEN_RXPEN | USART_ROUTEPEN_TXPEN;
void USART0_RX_IRQHandler(void)
// Get the character just received
buffer[inpos] = USART0->RXDATA;
// Exit loop on new line or buffer full
if ((buffer[inpos] != '\r') && (inpos < BUFLEN))
inpos++;
else
receive = false; // Stop receiving on CR
// Clear the requesting interrupt before exiting the handler
USART_IntClear(USART0, USART_IF_RXDATAV);
* @brief
* The USART0 transmit interrupt outputs characters.
void USART0_TX_IRQHandler(void)
// Send a previously received character
if (outpos < inpos)
USART0->TXDATA = buffer[outpos++];
else
* Need to disable the transmit buffer level interrupt in this IRQ
* handler when done or it will immediately trigger again upon exit
* even though there is no data left to send.
receive = true; // Go back into receive when all is sent
USART_IntDisable(USART0, USART_IEN_TXBL);
USART_IntClear(USART0, USART_IF_TXBL);
* @brief
* Main function
int main(void)
uint32_t i;
// Chip errata
CHIP_Init();
// Initialize GPIO and USART0
initGpio();
initUsart0();
while (1)
// Zero out buffer
for (i = 0; i < BUFLEN; i++)
buffer[i] = 0;
// Enable receive data valid interrupt
USART_IntEnable(USART0, USART_IEN_RXDATAV);
// Wait in EM1 while receiving to reduce current draw
while (receive)
EMU_EnterEM1();
// Disable receive data valid interrupt
USART_IntDisable(USART0, USART_IEN_RXDATAV);
// Wait in EM1 while transmitting to reduce current draw
while (!receive)
EMU_EnterEM1();
// Reset buffer indices
inpos = outpos = 0;
