I've set up an RS485 network with 4 nodes + my computer, which communicates via a USB-to-RS485 unit. The nodes are PIC16F345 processors, each with a MAX485 transceiver chip. It all works well in master-slave mode, with the computer as master, initiating every exchange. Now I'm wondering how difficult it would be to run the network as a token-passing system not requiring a computer. I've tried to find out whether anyone has done this before, in a minimal manner. It seems that token-passing schemes are quite complicated, and I don't want to use much of the processors' resources for this. How simple could a setup be, and still function robustly? It would need to start itself up, allow for nodes entering or leaving the bus, handle corrupted attempts at token-handling, and no doubt some other requirements I haven't thought of.
First of all, has this particular wheel been invented yet? I'd have thought that someone would have felt motivated to do it--but maybe it turns out to be so complex that a small processor can't handle it. Please don't say "Modbus"; that's master-slave only.
Second, is there any publication (preferably online) which describes the full requirements for such a system? If it hasn't been done already, I'd at least like to understand the features that a working system would need to have. Maybe then I'd decide that it's not worth trying, but at least I'd know why.
Here's my 4-node setup, with unit 25 controlling a couple of hobby servos, a reset switch on unit 40, and power to drive all the processors coming in on unit 26. The boards are meant to be linked by RJ12 connectors and cables, but I didn't have enough hardware to do it that way, so there are some other wires installed.
