So I'm trying to design this circuit which basically requires the following:
Design a circuit which has a DC power supply [12V/3A] to power (2x) solenoids [12V/2A] by connecting a relay to each solenoid (each relay can be powered by 5V), and (x1) Servo motor [6v/1A], and (x1) micro-controller [6V/1A].
Main components used:
1. Battery Lithium-ion Super Rechargeable Battery Pack (12V, 3000mAh)
2. JF-0826B Push Action Type Electric Linear Solenoid 12Vdc,2A
3. Servo motor (6V,1A)
4. Micro-controller (6V,1A)
NOTE: The original question is provided in the attached file in this post along with a diagram that could help more in understanding the problem.
Thanks in advance!
Thanks in advance!
