Hello everyone,
currently I'm working on a Project, if you could say so. I want to show the temperature on a 4 Digit - 7 Segment Display. I'm forced by the teacher to use an adc for my temperature sensor. So i searched on the web and find out that the ICL7116 is helpful. The only thing i still don't understand, is which Display I should use for and how the pins (2 up to 19) are connected to the Display(because as you can see in the picture, they only wrote LCD Display and there are no specific pin connections named). If someone could send me a fitting display and how I should connect these Pins, I would be thankful. (Datasheet: https://datasheets.maximintegrated.com/en/ds/ICL7116-ICL7117.pdf)
