I'm new to the world of electroncis and I'm trying to get my head around transmitting wireless signals.
I was pretty sad when I discovered most of those modules (nRF24, LoRa, 433mHz etc...) work only with microcontrollers such as arduinos, and if you don't have one you should use serial encoders/decoders.
All I have is a hall effect sensor with an analog output, so my problem is to transfer this analog reading wirelessly.
Converting the signal to a digital value is pretty straightforward, but can I directly feed the data to a "serial input" pin of one of those modules?
