Our Advanced Drive Assist Systems(ADAS) project is based on Renesas RH850/U2A16 microcontroller. We are using Infineon Technologies TLE75620-EST, SPI Driver for Enhanced Relay Control IC for driving loads. Datasheet is attached. We don't have any loads connected to SPIDER output pins. We're not commanding digital output logic low or logic high. On power up, SPIDER digital outputs pins are not stable. They are toggling between logic high and logic low. Attached is SPIDER OUT0_HS pin unstable waveform measured with oscilloscope.
When we stop code execution, output pin is stable. Please see attached SPIDER OUT0_HS pin stable waveform.
Microcontroller communicates with SPIDER chip over spi interface. Instead of stopping code execution, if we dynamically disable spi communications, would the digital output become stable?
Why is the digital output toggling? Microcontroller is using spi interface for control and diagnosis. Are we sending something over SPI that's commanding the digital output to toggle?
