Hello guys i want to build an inverter with 12VDC to 220VAC, 1000Watts
which type of battery, Mosfets and Transformer should I use
i want to run it for about 2 hoursHello,
Do you realize that 1000 Watts can lead to a current of about 100 A on the battery side?
How long do you want to run on battery?
Bertus
Next consider the size of the battery cables. Then under a full load the battery life.Hello,
Bertus
Then you would need at least a 200 Amp Hour battery or actually about a 250 AH battery.i want to run it for about 2 hours
ok what of 500 wattsIt's not that east, first consider this:
Most inverters offer a few wave shapes out like MSW (Modified Sine Wave) or TSW (True Sine Wave) with the latter being more complex. Which output wave form can you use? Inverters of this type are easier bought than built. They also normally use a 24 volt battery to reduce the current draw.
A simple Google of Inverter circuits should give you some basic diagrams.
Ron
Power is expressed in watts and in the interest of simple for now P = I * V or Power is the sum of the Current * Voltage. This is why 1000 Watts / 12 Volts = 83.33 Amps. That assumes a perfect world which things aren't. There are losses along the way, no inverter is 100% efficient. If an inverter was 80% efficient your battery draw would be about 100 Amps or actually slightly over. You want 500 watts? Then do the math.or
how much battery Ah and transformer Ah will i need
