Hi guys, I need to do a multiplier voltage with a load that use 0.6W of power (From 12Vrms increase to 64 V DC with ripler voltage of 0.5Vpp). The question is, how I calculate the value in farads of the capacitors that I need? Thanks for the help!
I don't think there is a way to do what you want to do. Capacitors are not used to multiply voltage. How about a schematic diagram of what you have in mind.Hi guys, I need to do a multiplier voltage with a load that use 0.6W of power (From 12Vrms increase to 64 V DC with ripler voltage of 0.5Vpp). The question is, how I calculate the value in farads of the capacitors that I need? Thanks for the help!
If I change the value, the voltage changesDo you get the same voltage or a different voltage if you use a different value?
Slightly. For 100u the output is about 60 Volts. For 620u to 1000u it goes from just under to just over 64 Volts. The value is not that critical. Even if it was you can't get that size capacitor from the E48 or E96 series, so you get close and call it a day.If I change the value, the voltage changes
