How about showing us this circuit so that we might suggest a solution?closes and opens (ON-OFF) the circuit instantly
I'm not aware of any mechanical switch out there with the behavior that you want. Although I know of several mechanical contraptions that would do the job, if adapted properly.I am not searching for a circuit, but for a component!
I am searching for this specific switch, if it exists ..
Did you read about a piezo switch? (https://en.wikipedia.org/wiki/Piezo_switch ) They exist.I am not searching for a circuit, but for a component!
That is one solution (the relay), but I want one component...Search on "pulse switch" or "piezo switch." Here is one version: https://electronic-products-design....ics/filters/convert-toggle-switch-on-to-pulse
I think it can also be done with a relay and double pole switch. Wire the switch in series with the relay so that the relay opens the other circuit that the switch closes. That way the switch can keep the relay pulled in , which will keep the circuit to the other pole open.
by Jake Hertz
by Duane Benson
by Jake Hertz
