Hi, I want to make a serial I2C communication with pic18f4520 in mode slave
P Thread Starter pauloDNS Joined Jul 19, 2020 25 Aug 29, 2020 #1 Hi, I want to make a serial I2C communication with pic18f4520 in mode slave
P Thread Starter pauloDNS Joined Jul 19, 2020 25 Aug 29, 2020 #3 MaxHeadRoom said: Help in - Hardware? Software? Both? Max. Click to expand... software
P Thread Starter pauloDNS Joined Jul 19, 2020 25 Aug 29, 2020 #5 MaxHeadRoom said: Assembly? C ? Max. Click to expand... If you can in both
MaxHeadRoom Joined Jul 18, 2013 28,696 Aug 29, 2020 #6 See Piclist for some routines, Also on the Picmicro site there is app note, TB3281 getting started with the I2c and Pic18. Maz.
P Thread Starter pauloDNS Joined Jul 19, 2020 25 Aug 29, 2020 #8 upand_at_them said: MPLAB Code Configurator? Click to expand... yes
upand_at_them Joined May 15, 2010 940 Aug 29, 2020 #9 I'm suggesting that you use it to generate the code.
MaxHeadRoom Joined Jul 18, 2013 28,696 Aug 29, 2020 #10 If you have it or can still get it, there is the older Picmicro Maestro code generator if you need it also in Assembly. Max.
