How to convert this oscillator to VCO ?
GTelly
Joined Jul 8, 2020
This is my first post ever on this forum :) During the lockdown, I decided to relaunch one of my very old project: building a modular synthesizer. Not by copying without knowing what I'm doing but by trying to design by myself (not starting from scratch though). I read a lot of books including make synthesizers of the art of electronics focusing on the basics and oscillators.
In my learning quest, I found this nice oscillator design that seems good for the first module of my synth: the VCO. (so yes, it's a copy, but it's for learning purposes :) )
Yet, probably there's something I don't understand yet : how can I transform this oscillator to a VCO ?
I mean: modifying R5/C1 permit to change the frequency. But how can I change it by increment of volts through a control voltage (all I want for now is a linear control voltage in the audio range)?
I think to FET as a resistor (not linear) and I tried to put a current source at various point without much success... (I'm ready to be ashamed :)) )
Thank you for your help !
OBW0549
Joined Mar 2, 2015
3,566
What's "nice" about it? It looks like a hot mess to me, far too complicated for what little it does.
You can't. Conventional oscillators and voltage-controlled oscillators are RADICALLY different things.
Forget it. Either use the circuit above posted by @Audioguru again or use something like an XR2206 (available through Jameco, Mouser or Sparkfun).
ci139
Joined Jul 11, 2016
1,898
as far as i get it's a pretty cool comparator circuit . . . the R10 R11 adjusting duty ratio , but it's an unsafe option as the oscillations may stop at certain setting . . .
the VCO design depends on what features of the existing circuit you want to preserve
. . . a bad idea , but a one possibility http://tinyurl.com/y7y2ft82
Papabravo
Joined Feb 24, 2006
21,227
I decided to play around with the above mentioned VCO and discovered to my surprise that the LM358 model in my LTspice library was crashing the simulator. That's a bad bad thing. I recently installed the collection of Alex @Bordodynov , and using his functional model of the LM358 things came back to normal. I include the .asc file in case anybody wants to check their own LM358 model.
Let me know if you stumble across anything interesting.
Спасибо, Alex.
Papabravo
Joined Feb 24, 2006
21,227
In case you're bored to tears, and would like to test your Analog IQ. What component in the VCO of post #5 in this thread determines the maximum frequency that you can get from this VCO?
  1. Is it capacitor C1?
  2. Is it the LM358_AB?
  3. Is it Q1?
  4. Is is any of the resistors R1 thru R7?
  5. Would a real part behave differently than the simulation?
I think I know the answer, but I'd be interested to hear your opinion. go ahead and run the simulation if you like - all's fair in Analog Contesting.
If you'd like any of the supporting files I can post those as well, but only on request.
Zeeus
Joined Apr 17, 2019
616
Please post the .asc
Couldn't get it to work
Zeeus
Joined Apr 17, 2019
616
  3. Is it Q1?
I think the op amp (and it seems circuit not working on spice with R as 100 ohms)
With the comparator like that. change in V (dv) = 4V
Vi input voltage
frequency = Vi/ (4*R*C*dv). R of first op amp
Maximum frequency? then op amp. What frequency do you want?
Anyways, thanks for circuit
And please why does vi have to be 1.5V less than Vcc ?
GTelly
Joined Jul 8, 2020
Hello ! Sure, it seems a nice design.
Thank you. By "nice", I meant that it seems to fill my need (triangle / square wave without any amplitude drop on the triangle). Probably, it's a mess and I trust you :)
So now I know that OSC and VCO are something really different. I was unsure of that and it's why I finally decided to ask here after many hours trying to figure out.
OK for the LM358 circuit. I will try that !
Alec_t
Joined Sep 17, 2013
14,332
I found a year or two back that the LM358 model I had would crash the sim if there were two or more instances on the schematic, but the sim would usually run ok if there was only one instance. I now have 3 models in my armoury; from TI. ST and NS respectively. However, whenever I go to use one, I've forgotten which one was best :). The LM324 model has similar issues too.
