Technics SUV4x Power Supply Issue Help
ssid
Joined Jul 7, 2020
35
Hi
Got the Technics SU-v4x amp as spares or repair. Fancied a challenege to see if I could fix it as I like them. Seller said it was working until it started going into protection from time to time but now full time.
Burned a cap C523 as soon as I plugged it in > replaced it > OK
Checked the pre drive transistors Q501 - 4 >OK
Checked for cold solder joints > nothing yet
Input selector does not work properly as it does not show red led selection. Only the yellow tape source selection.
Track on circuit board had been previously repaired. Cheked it
Eventually I got it out of protection mode by replacing C523 and R535 which had also blown. Also replaced relay as it was stuck.
The input selector still does not work properly - only the tape select works so no sound. I think it is a power supply issue but cannot work out what to do next.
The 50v rails are fine but the issue is with the 15v rail which supplies the various tone / selector / phono pre amp boards via jumpers is running at 1.89 volts.
All the Q701 - 5 regulator transistors seem to be OK (Not checked Q705 yet). The 4 rectifier diodes are OK I think with 2 showing 50v in one direction and the other two showing the same in the opposite direction.
I feel I am on the cusp of kind of fixing it or maybe not as it may just go into protection mode again if I get the 15v rail back!
Any help would be appreciated. Attached is the service manual.
AlbertHall
Joined Jun 4, 2014
12,346
What is the voltage across D706 and R702?
D706 sets the output for the -15V.
The voltage across R702 tells us how much curretn is being drawn from the -15V.
ssid
Joined Jul 7, 2020
35
Hi AlbertHall - I really appreciate your input as I am learning how to do this and can only get so far before I get stuck!
D706 = -0.644v and 0.3 mv
R702 = -50.8 v and -51.6v
Just an observation. If I unplug all of the boards the J connector negative voltage on the main board goes up to -18-20v.
AlbertHall
Joined Jun 4, 2014
12,346
Ok. There is 50V across R702. From the parts list that is a 470 ohm, 0.5W resistor. 50V across 470 ohms means that there is 5W beIng dissipated in that resistor. That would burn up that resistor pretty quickly. There are two possibilities:
1. The resistor is open circuit (or high value) - with it switched off measure the value of that resistor.
2. There is a near short circuit on the -15V output somewhere and the only thing there to limit that current is R702. The fact that the voltage is near normal when disconnected suggests this may be the case (but still measure the value of R702).
If R702 value is correct then carefully inspect the rest of the circuit for damaged or burnt components, leaking or bulging electrolytic capacitors, or anything else that looks suspicious.
ssid
Joined Jul 7, 2020
35
Hi. Thanks for the quick response
In circuit the R702 is measuring 0.447 k ohms but I can remove and measure properly if needed. It looks like it is in good condition.
Are there any specific components that I should check or should I be looking near R702 or the whole 15v circuit across multiple boards?
ssid
Joined Jul 7, 2020
35
I also replaced C201/2 on the phono sockets input board as when I first got the amp it looked like they were smoking as the amp was full of dust.
ssid
Joined Jul 7, 2020
35
C707/8 are near where we have been looking at. They look OK but I could replace them quite easily as I have them in my toolbox? Is it worth a try?
AlbertHall
Joined Jun 4, 2014
12,346
And when it is switched on there is about 50V across the resistor - that is with one meter lead on one end of the resistor and the other meter lead on the other end of the resistor?
AlbertHall
Joined Jun 4, 2014
12,346
I am a little confused.
Measure the voltage on each end of the resistor to chassis ground.
Then lift on end of the resistor and check its value.
ssid
Joined Jul 7, 2020
35
Hi
R702 Chasis to ground -50.8 volts and -51.5v
Not sure what you mean by ("Then lift on end of the resistor and check its value. ") , but if I directly put the probes on either side of the resistor and switch to Resistance mode on the DMM it shows 0 with power on. With power off after a period of time the resistance starts to rise and now appraching 400 ohms and rising.
30,806
You are committing fundamental newbie mistakes.
1) You NEVER attempt to measure resistance with any ohmmeter (or DMM in resistance mode) in a circuit while the power is ON.
You are at risk of blowing your DMM.
2) Measuring resistance of any component while still in circuit will be affected by the rest of the circuit. In order to obtain an accurate measurement at least one end of the resistor must be disconnected. This is what @AlbertHall means when he says "lift one end of the resistor".
30,806
@AlbertHall might have misread your voltage readings taken at R702.
According to your readings reported in post #3
Hence the voltage across R702 is 0.8V, not 50V.
AlbertHall
Joined Jun 4, 2014
12,346
I am suspicious of Q702 - which you say you have tested.
Can you remove Q702 and then switch on the amp and measure the voltage across D706.
Check the marking on Q702 - should be A1112 -R as below.
What do you have for testing this transistor? A DMM with a diode check range?
ssid
Joined Jul 7, 2020
35
Hi. Had to go out.
Thanks for the advice on using the DMM and measuring resistance while the power is on Mr Chips
I used a transistor tester to check Q702, however sometimes they can be inaccurate.Q702 is as shown on the picture
bjt-pnp
123 =ecb
hfe=109
vf =604mv
With power on for Q702
c = -50.2v
b = -0.920
e =-3.722 mv
Voltage across D706 = -0.927 and 0.3mv with Q702 removed
What was strange was that it did not go into protection mode with Q702 removed. Possibly becuase the current is so low.
abrsvc
Joined Jun 16, 2018
138
Try lifting the power pins on IC201 and IC 202 (TC9163 and TC9164). These are common failures for units of this vintage.
