Thank you in advance for any advice you can offer, because I'm very much a novice at this. I'm sorry for such a lengthy post but figured I'd at least do the courtesy of explaining my situation as best I can to anyone kind enough to help.
Goal:
Create a second turn signal indicator LED on my motorcycle. The one on my bike (12 below) is mounted way below my field of vision so I sometimes forget to turn off my indicator and the indicator light flashing on the tank remains unseen. Having another LED light flashing - when indicating - at a higher position would help.
The manufacturer's Wiring Diagram
Mine is the Australian (A) version of (10) and (11)
Here's what I found and what I tried
I found the GY (grey) and G (Green) circuits Ok, being the left and right indicator circuits (5, 6, 10,11).
If I wired both GY and G to the +ive of the new LED [let's call this (99)], all four indicators would flash as if on hazard lights. Ok - makes sense.
So logically (I thought), I need an XOR between GY and G to power the +ive of the LED at (99) and ground out -ive. Being a newbie, I thought I might place a small SPST relay on each GY and G separately, with only one circuit ever active and the two never meeting to form hazard lights! I used the FRA7TA from JayCar (SY4029). This actually worked soldering to its PCB connectors, but the new LED (99) seemed very dull - so dull that I couldn't see it in daylight - unlike the original at (12) which is very bright. Humm. BTW - there is no access to (12) being in a sealed unit.
I thought the new LED (99) might normally be that dull so thought I might switch it for a small strip of LEDs [call it (100)] which I know to be bright when tested with a 12v battery directly. I figured, even if low voltage is getting to (99) - the combined output of the two relays, replacing the dull lamp with a bright LED strip (100) would be fine.
Now - here's what has really thrown me.
The LED strip (100) didn't even come to life but I did register the smallest dim light on one or two of the 8 tiny LEDs in the strip (100). Didn't expect that! So I wired in both (99) AND (100) at the same time. The dull (99) showed again - as before - and the LED strip (100) remained inactive. But at least (99) was working - even if the LED strip (100) stayed unlit. This is were I stopped - totally confused as to the root cause. Self-admitting, I clearly don't know what I'm doing.
My volt meter, when the indicators are flashing, never seems to read above ~5v when sampled at (99) or (100). I'm not sure if it's because the voltmeter is not sampling fast enough on the flashing line to see it higher or if it truly is low voltage.
My gut tells me that it's voltage from the two new SPST relays (2x FRA7TA) may be too low, but they're both 20AMP 12 relays. Perhaps having the output of the two relays joined to a single +ive out has halved my voltage for some reason - say "reverse" powering the other relay which would always be idle. I hope this makes sense?!
Where to from Here?
If I have to start again - that's Ok. I'm happy to do it all over as a learning experience.
I did wonder if I used the (possibly) low voltage I am getting to trigger a 3rd new relay then pull a full 12v batter power directly through the 3rd relay, that might get me the result I want, but I feel that I'm over-complicating it to hell and better to ask.
I'd be very grateful for any assistance/advice.
Goal:
Where to from Here?
