Can you make a boost (or buck) converter using a capacitor instead of an inductor?
jayeshshetty
Joined Jul 3, 2020
Forgive my electronics ineptitude if this is a stupid question, but I was thinking that if capacitors are used to store the energy supplied by the bridge rectifier in unregulated AC power supplies then what means they can't be used to store the energy in a boost converter (or buck converter) while the MOSFET (or whatever's switching) is turned off? I looked and couldn't find if this has been done before, so if it's not possible could someone explain to my why? Thanks in advance.
jpanhalt
Joined Jan 18, 2008
11,087
Welcome to AAC.
Note that while both component's store energy, the inductor can boost voltage; whereas, the capacitor can boost current, but not voltage.
This link address that: https://electronics.stackexchange.c...osition-of-the-inductor-and-capacitor-in-this
As for the "low-pass" filter nature of a boost converter mentioned in the above link, a capacitor would not conduct DC.
Now, using different topologies, you can increase voltage with a capacitor and no inductor:
1) Cockcroft-Walton voltage doubler (https://en.wikipedia.org/wiki/Cockcroft–Walton_generator )
2) A related, switching capacitor voltage doubler: ICL7660 and related charge pumps (https://pdfserv.maximintegrated.com/en/ds/ICL7660-MAX1044.pdf ).
However, those capacitor-based devices are suitable for low currents only.
EDIT: I forgot to mention a common use for capacitors to boost or to invert voltage is to provide bias voltage to LCD displays. All you need is a square wave (such as produced by an MCU). Input goes to C1:
Source: http://ww1.microchip.com/downloads/en/DeviceDoc/01146B.pdf
Papabravo
Joined Feb 24, 2006
21,225
jayeshshetty
Joined Jul 3, 2020
Thank You So Much
________________________________________________________________________________________________________
