1. I have written below code, have to just read the times from RTC. So I read all registers starting from 0x00.I always zero from RTC DS1307.
2. Time is set by Arduino board separately and I can read back by arduino correctly. So no error seems in RTC board.
But now I have to implement in another MCU with bit banging only.
3. Have checked all pull up values ok and pin scl and scd getting high and low for output_low or output_high.
Code:
#define ACK 0x00
#define NACK 0x80
#define RTC_WR 0xD0 // WRITE instruction
#define RTC_RD 0xD1 // READ instruction
void rtc_init(void)
scl_high();
sda_high();
sda_output();
scl_output();
void read_rtc_registers(uint8_t time_arr[])
uint8_t temp[7];
uint8_t val1,val2,val3;
i2c_start(); // generate Start COndition
i2c_wr(NAU7802_WR); // send WRITE command
i2c_wr( 0x00U ); // address from 0x00 i.e seconfs
i2c_wr(RTC_RD); // send READ command
temp[0]=i2c_rd(ACK); // read data from buffer
temp[1]=i2c_rd(ACK); // read data from buffer
temp[2]=i2c_rd(ACK); // read data from buffer
temp[3]=i2c_rd(ACK); // read data from buffer
temp[4]=i2c_rd(ACK); // read data from buffer
temp[5]=i2c_rd(ACK); // read data from buffer
temp[6]=i2c_rd(NACK); // read data from buffer
i2c_stop(); // send Stop Condition
void rtc_wr_byte(uint8_t addr , uint8_t data)
i2c_wr(RTC_WR); // send WRITE command
i2c_wr( addr ); // address MSB
i2c_wr(data); // send data
i2c_stop(); // initiate Stop Condition
ack_poll(RTC_WR); // ACK polling
uint8_t rtc_rd_byte(uint8_t addr)
uint8_t data;
data=i2c_rd(NACK); // read data from buffer
return data; // return data from I2C buffer
void i2c_start(void)
sda_input();
scl_high();
sda_output();
sda_low();
__no_operation();
__no_operation();
scl_low();
void i2c_stop(void)
scl_low();
sda_output();
sda_low();
__no_operation();
__no_operation();
__no_operation();
scl_high();
sda_input();
__no_operation();
__no_operation();
__no_operation();
scl_low();
void bit_out(uint8_t data)
scl_low();
sda_output();
if(data >> 7U)
sda_high();
else
sda_low();
__no_operation();
__no_operation();
scl_high();
__no_operation();
__no_operation();
__no_operation();
scl_low();
void bit_in(uint8_t *data)
scl_low();
sda_input();
scl_high();
__no_operation();
__no_operation();
__no_operation();
if(sda_read())
*data |= 0x01;
scl_low();
uint8_t i2c_wr(uint8_t data)
uint8_t i; // loop counter
uint8_t ack; // ACK bit
ack = 0U;
for(i = 0U ; i < 8U ; i++) // loop through each bit
bit_out(data); // output bit
data = data << 1; // shift left for next bit
bit_in(&ack); // input ACK bit
return ack;
uint8_t i2c_rd(uint8_t ack)
uint8_t ret = 0U; // return value
ret = ret << 1; // shift left for next bit
bit_in(&ret); // input bit
bit_out(ack); // output ACK/NAK bit
return ret;
void ack_poll(uint8_t control)
uint8_t result = 1U;
while(result)
i2c_start(); // generate Restart condition
result = i2c_wr(control); // send control byte (WRITE command)
i2c_stop(); // generate Stop condition
