So I have an AC circuit interrupted by this old relay board. It has 2 connections on its channel, which is basically where i run the circuit wire thru. Its an SPST-NO relay.
I have to switch over to this spdt switch and I need to wire it up. How would I wire it up in that case based on my 2 wires from the spst relay?
Im thinking i would need to connect one of the wires to the Common and the other wire to any of the 2 terminals (NC/NO)? Probably NO.
