Hi There,
This is my first post at the forum and I really do not know what I am doing wrong. I read the datasheet, watched tutorials, looked at the forum posts but could not find any proper reason for why it is not working.
I explained what code does at comments but in summary, it counts every one and two seconds to toggle LEDs. LEDs are initially ON but interrupt never happens after code starts. I used a 16-bit timer (timer1) and avr/interrupt library which saves me from writing all the code for sei() function. However, I try to use the ınterrupt function which compares using comparator a which gives the opportunity to range between 0 to 2^16 but I am using only 999.
I used Prescaler which divides frequency to 8 and since set tick number set as 999 at the previous part, interrupt must occur every 1milliSecond due to math (8 000 000)/(1000*8)=1000Hz. So I used counters in interrupt function which counts 1000 and 2000 times when zero crosses occurs and the main function calls for led blinking functions. By math (Since 1000hz = 1/1000 sec, 1000*(1/1000)=1sec or 2000*(1/1000)=2sec) main function calls the led blinking functions every 1 second for one led and every 2 seconds for the other led.
But it never happens and I do not understand why. Also, do you have any advice which is better than doing all this stuff for getting a specific time for check some function over and over again?
Best Regards,
Selim.
Best Regards,
Selim.
C:
* InterruptwithMega8.c
* 16
* Created: 05.06.2020 22:07:46
* Author : Selim Keles
Using timer1(16bit timer) with 8 Mhz internal oscillator. Every 1mSecond interrupt occurs due to math 8 000 000 /8/1000 = 1000Hz.
So I add a counter in interrupt which counts to 1000. After 1000 count (1000*(1/1000)=1s), ledblink function will call.
#define F_CPU 8000000
#define firstledtime 1000 //d0 pin will blink every 1 second
#define secondledtime 2000 //d1 pin will blink every 2 sec
volatile unsigned int t1; //Flag for first led which I used in interrupt
volatile unsigned int t2; //Flag for second led
#include <avr/io.h>
#include <avr/interrupt.h>
void init(void); //Inıt function
void blinkled1(void); //Function which toggle led1
void blinkled2(void); //Function which toggle led2
int main(void)
init();
while (1)
if (0==t1){t1=firstledtime; blinkled1();}; //Calls the function if 1 second passed. (1000Hz*1000=1second)
if (0==t2){t2=secondledtime; blinkled2();}; //Calls the function if 2 second passed. (1000Hz*2000=2second)
void init(void){ //init function
cli();
DDRD |= (1<<DDD0) | (1<<DDD1); //D0 and D1 ports selected as output
PORTD |= 0x03; //Leds are initially on
TIMSK|=OCIE1A; //Mask will be compare with comparator A. If match occurs interrupt function will be called.
OCR1A|=999; //8Mhz/8/1000 =1000 frequency is 1000. t1 and t2 will count to 1000 and 2000 in interrupt function to reach 1 sec and 2 sec
TCCR1B|=(1<<WGM12) | (1<<CS11); //Prescaler is 8 and CTC active which clears counter obtained by prescaler and thick counter
t1=firstledtime; //initially set to 1000 because ı will decrement it in interrupt function
t2=secondledtime;
sei(); //Interrupts are active
void blinkled1(){
PORTD ^= (1<<PD0); //Toggles Led1 at port d0
void blinkled2(){
PORTD ^= (1<<PD1); //Toggles Led2 at port d1
ISR(TIMER1_COMPA_vect){
if (t1>0){--t1;}; //decrements t1 from 1000 to 0 which helps to obtain 1 sec
if (t2>0){--t2;}; //decrements t2 from 2000 to 0 which helps to obtain 2 sec
