Hi friends,
I made the circuit stated above. It works perfect but the sound pressure is not high as much as I wish. I use a 16 ohm horn speaker and strongly probable this is the reason for relative low sound pressure. The other factor maybe the car battery supply voltage ( 13.5 v ). My questions are stated below.
1- Does it work if I step up the battery voltage up to 18 v or 20 v by a DC to DC converter ? Do I catch approximately 120 or 130 dB ?
2- TC 1411 safe side working voltage is up to 16 v. Can I use suitable resistance serial to power (+) leg in order to keep it in this safe margin ? If yes what should be the value of this resistance if I power it with 18 v or 20 v ?
3- May a step up audio transformer be connected directly to the speaker output ? If yes what should be the winding turns and wire thicknesses ?
4- If I make the circuit stated below, does ancient TDA 2050 catch the 120 or 130 dB if they are connected as bridge and powered +/- 18 volt symmetrical ?
I have to use 16 ohm horn driver.
Thanks in advance for your comments and suggestions.
Cheers
Cheers
