please what will the output waveform of a pwm signal look like after being switch by a mosfet or transistor. Especially in smps. Will the frequency of the pulse increase or decrease or will everything remain the same.
The frequency of the pulses will depend on the circuit driving the MOSFET. In a power supply it may vary with the demands of the load or the frequency may stay the same and the duty cycle may vary. The shape of the MOSFET output waveform will depend on what kind of load is being drivenT.please what will the output waveform of a pwm signal look like after being switch by a mosfet or transistor. Especially in smps. Will the frequency of the pulse increase or decrease or will everything remain the same.
ok you mean that the load will automatically influence the switching frequency of the pwm ic, and also the output waveform of the switching mosfet . Is that it?The rate (or frequency) at which the power supply must switch can vary greatly depending on load and application. For example, switching has to be done several times a minute in an electric stove; 120Hz in a lamp dimmer; between a few kilohertz (kHz) and tens of kHz for a motor drive; and well into the tens or hundreds of kHz in audio amplifiers and computer power supplies. The main advantage of PWM is that power loss in the switching devices(Your MOSFET) is very low. When a switch is off there is practically no current, and when it is on and power is being transferred to the load, there is almost no voltage drop across the switch. Power loss, being the product of voltage and current, is thus in both cases close to zero.View attachment 206649
Are you saying that the load will automatically influence the switching frequency of the pwm ic, and also the output waveform of the switching mosfet .The frequency of the pulses will depend on the circuit driving the MOSFET. In a power supply it may vary with the demands of the load or the frequency may stay the same and the duty cycle may vary. The shape of the MOSFET output waveform will depend on what kind of load is being drivenT.
Regards,
Keith
"automatically influence" We have a power supply with a load. It has been working for a long time. The output voltage is what we want. (5.000 volts) The error amplifier see 5V and is happy. The load increases. This causes the voltage to start down. The error amplifier now sees 4.999 volts and it calls for the duty cycle to increase. The duty cycle will keep increasing until the output is back to 5.000 volts. Now the duty cycle will hold at this new duty cycle.Are you saying that the load will automatically influence the switching frequency of the pwm ic,
Ok thanks, the feedback tends to adjust the duty cycle of the pwm signal that was generated by the ic, before it is fed to the gate or base of the power transistor by the help of a reference voltage.There are a number of different types of power supply that switch MOSFETs on and off to regulate the supply to a load. Each type has it's own unique way of handling feedback and controlling the FETs. Some use a fixed frequency and vary the duty cycle. Some use a fixed pulse length and vary the frequency. Some just switch on the FETs whenever the load demands it and switches off when the requirements are met. I hope this answers your question.
Regards,
Keith
Ok it reaction is all dependent on the control ic or pwm generator ic?The power transistor (either BJT or MOSFET) just acts as a switch in a SMPS, so it has no significant effect on the frequency or duty-cycle of the signal.
Ok thanks, but when we talk of error amp, is it the optocoupler?"automatically influence" We have a power supply with a load. It has been working for a long time. The output voltage is what we want. (5.000 volts) The error amplifier see 5V and is happy. The load increases. This causes the voltage to start down. The error amplifier now sees 4.999 volts and it calls for the duty cycle to increase. The duty cycle will keep increasing until the output is back to 5.000 volts. Now the duty cycle will hold at this new duty cycle.
If the load is reduced the output will start up. 5.001V will cause an error voltage and push the duty cycle down until the voltage is back to 5.000 volts.
Automatically? There are parts that make this happen. (error amp and reference voltage)
nobut when we talk of error amp, is it the optocoupler?
ok thanks a lot, u have really put me at ease.Error amp with isolator:
R3 & R5 in this case divides VOUT down to 2.5V. The TL431 has a reference voltage of 2.5V, and has a op-amp.
The TL431 amplifier the difference of Vout and Vref. Current goes through R1 and the LED in the isolator. The isolator output sends information to the PWM. If VOUT is low then the "R" pin on the TL431 will be low. This causes the "K" pin to be high and little current will pass though U1. This tells the PWM to work harder. If Vout is too high, K is low passing large current in to U1. This tells the PWM to work less.
More information please. Schematic?i came across a compensation circuit and a current sensor still in the feedback loop
Ok thank you very much for bringing the circuit as well.More information please. Schematic?
Compensation: A power supply of any kind can oscillate. It is important to have a very high gain error amplifier at DC or low frequencies, but high gain at 1khz will cause the supply to oscillate. (phase shift oscillator)
If you want 10.000V not 10.001V or 9.999V you need a amplifier that can see 0.001V and amplify it. But a gain of millions at 10khz will drive the power supply crazy. Look at the amp in post #16. There is a capacitor from input to out put. At low frequencies the capacitor is "open" and allows the amp to have high gain. At high frequencies the cap reduces the gain. This next graph shows the gain of an error amp verses frequencies. My guess is that this supply wants to oscillate at 10khz. Red line is gain. The amplifier has a max gain of 63db. The gain gets smaller at high frequencies. A little complicated and lots of math.
Here is a isolated power supply. If it was a dc to dc supply with no isolation then every thing in the blue box can be removed and the error amp in the green box would do the job.
Ok so the capacitors acts as the compensation circuit or ...More information please. Schematic?
